Remembering view alignment of sketches
When I edit a sketch Inventor takes me to a 'default' view of the sketch, and quite often it's not orientated in the way that I want -
quite often I'll want to view the sketch from a particular side, or alignment which doesn't correspond with the WCS/UCS, this is annoying and time consuming to re-adjust each and every time I go into a sketch.
Thus I'd like to see Inventor remember the view alignment of each sketch previously worked on so that when it's edited the sketch is viewed in the correct attitude.
1 Comment
ic198
Good idea. It would also be good if the sketch view remebered other details, such as if Section on Sketch Plane (F7) was activated, if bodies/surfaces/planes etc. had been shown or hidden while editing the sketch, if wireframe view was in use etc.. Basically I would like each sketch to create and remeber it's own View Representation (these don't need to appear in the view reps menu), and automatically activate it when editing that sketch.
