When I receive a 3D neutral file such as a Step file, the coordinate system may not be set in the desired direction.
I can use Viewcube to redefine the front view, but it only changes the view of the part and the actual coordinate system stays the same.
So it is very inconvenient when placing parts with problems in the coordinate system into the assembly environment.
Can you make a way to redefine the coordinate system in Inventor?
(For example, insert UCS and reassign the coordinate system with it)
