Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Real Thread Modeled
Real Thread Modeled
Maybe there are already similar ideas..
But.
If you want a real modeled thread in Inventor what do you do?
1- you have to model it by yourself (sketch...coil/sweep, etc)  (db18cec69d42acd83a8a8fb084e50d4f
2- you have to use a third part app called "coolOrange threadModeler". ( We-think-Tired-yawning-surprised
But...why?emojipedia-colbert-emoji-sample
We (I) would like to see this!
172 Comments
jgarzaSFQ2Z
Maybe they will combine Fusion and Inventor into...........................Autodesk Infusion.
@jgarzaSFQ2Z  Surely you mean Autodesk Confusion.
jgarzaSFQ2Z
@This_Username_is_Taken
That's even better. Autodesk Confusion Professional.
JusticeSmith
Hahaha. My Inventor teacher at college (2019) works for Autodesk and was trying to tell us that fusion would replace Inventor. I believed him then, but now, not so much. Inventor's workflow is just superior for large organizations, and Fusion is good for smaller projects and DIY.
Now there are things Autodesk would benefit from building on in Inventor, such as Frame Generator, Drawing features like sketch symbols, etc... Model States is a huge step in the right direction. I would like to see folders added though!
a.grolleau
In the meantime, 'thread modeling' is already implemented in Fusion but still not in Inventor. They seem more focused on perfecting Fusion so it’s no longer just a 'DIY tool' rather than enhancing Inventor, which isn’t really evolving anymore.
JMR_Silgan
I would like to refresh this request.  As a 3D printing specialist, it annoys me that I can't print threads.  The Cool Orange add-in no longer works with the current build of Inventor, so leaves me with nothing but manual thread modeling.
steinar_sorem
Hi
You can change Inventor version in the config file in program folder to let it run for newer version of Inventor
andreas.sydlik
In metalworking, mechanical engineering and vehicle construction as well as in agricultural machinery and precision technology, standard threads according to ISO and ANSI are often required. Unfortunately, thread modeling is not available in Inventor, unlike Fusion and FreeCAD. However, thread modeling is a very important part of daily design work, also with regard to modern 3D printing. It would therefore be very beneficial to have thread modeling of both standard and trapezoidal threads implemented in Inventor. Please check that. That would be really cool. Greetings from Germany
Tags (2)
MKE_Howard
Theres already a popular idea for this : Real Thread Modeled - Autodesk Community
Also there are add-ins availble. I never thied this one but could help you : threadModeler | Inventor | Autodesk App Store
And you can always make it yourself but its a bit complicated for beginners : 3D Printable Threads in Autodesk Inventor
Another solution posted by @jingyi.liu is this : Home - threadModelerOnline
andreas.sydlik
hey howard,
thanks a lot for your message. I tried all that stuff but that not
really good like in FUSION or FreeCAD. In NVENTOR 2021 there existed an
good tool from COOLORANGE, but in actual versions it doesnt run an
online there a lot of problems with the differen version.
MKE_Howard
It’d be awesome if Inventor could get more features from Fusion. I’ve tried my best to help out.
Wäre super, wenn Inventor mehr Funktionen von Fusion bekommen würde. Ich habe mein Bestes gegeben, um zu helfen.
andreas.sydlik
hi howard,
yep, you are right. thanks a lot for your support with this ...
andreas.sydlik
I checked COOL ORANGE.  it can not produce trapeziod threads only standard threads. And tere are too many steps in the model-browser.
christophe.portier
I'm reviving this thread because version 2027 has just been released and there's still no 3D modeling for tapped holes and threads.
I think I'm not the only one waiting for this feature; it's about time it was integrated into Inventor.
a.grolleau
Honestly, I no longer expect this feature in Inventor, since they’ve already integrated it into Fusion some time ago. I just get the feeling that they’re keeping Inventor on life support and will eventually push us toward Fusion, probably simpler for Autodesk. It’s very disappointing to have a platform like ‘Inventor Ideas’ and then seemingly not care at all. This thread has gone on too long without any response to believe that Autodesk is taking it seriously. (10years) 😤
CoolOrange has dusted off its thread modeler and made it available in the Autodesk app store again.
Not the best solution, but it (sort of) works.
christophe.portier
@a.grolleau
Having personally tested Fusion, there's no chance I'll switch to it right now. It's completely unsuitable for my job (I design large assemblies and special-purpose machinery), so Inventor remains the gold standard for me. If Autodesk decides to discontinue Inventor tomorrow, leaving only Fusion, I'm almost certain I'll switch to the competition, despite my more than 25 years of using Autodesk products.
Yes, the Coolorange thread modeler works. My only criticism is that it's limited to just two standards (metric and imperial). The parts I design and have 3D printed (titanium, stainless steel, aluminum) often use cylindrical or tapered gas threads, with or without sealing, so I can't use it. If Coolorange decided to implement these thread formats, it would be a step forward while we wait for Autodesk to integrate the feature into Inventor (I know, Santa Claus is on December 25th 😀).
david_jones4
I agree that Fusion is not a replacement for Inventor and likewise if they stopped it and tried pushing me to Fusion I would have to jump ship. I've tried using Fusion but it's not Inventor, although its CAM capabilities for me are simple to use and good for my needs.
I've tried probably all the other 3D packages and still like Inventor, plus I have years of legacy data, but it's definitely lagging behind the others for new features and even old features like thread modelling.
I've been with Autodesk from before the days of Inventor with Mechanical Desktop and the days before subscription. One of their selling (forced selling) points for going subscription was to allow them to develop and improve each new release.
As someone who's been with them since the days of Autocad in DOS this is nothing new, or should I say, there is nothing new.
WillL84
Agreed. I tried using Fusion but after learning CAD with Inventor I can't stand the Fusion interface. I use it at home though and I'm so programmed to know where features are in Inventor that I end up spending more time looking for where they are in Fusion than doing actual work. I also hate having everything on the cloud with Fusion. We have a server here at work with all of our CAD files with offsite backup. I hate to think what would happen if something happened to the Fusion servers accidentally and everyone's stuff just disappeared one day.
We have the PDMC at work so we get Fusion. 99% of the time I only use it for CAM and the other 1% is adding modeled threads to something I need to 3D print because I can't do this simple thing in Inventor without having to sketch the threads and do a revolve which  is annoying. CoolOrange works OK most of the time but I always have to go in and add chamfer cuts or something to the threads afterwards.
david_jones4
I have the same issue with Fusion and I don't understand why they invented a new package that works in such a different way to Inventor which works. I design in Inventor and use Fusion for CAM.
Inventor is a good package it just isn't updated enough. Especially considering the cost. Did I mention Subscription which I hate.
I had a work experience lad with me for a few days and he had only ever used solidworks with it being free/subsidised to universities and students.
He took to Inventor very quickly and even said he preferred how it did things. Easier than Solidworks, but lacking Solidworks features.
Inventors been lacking even the most basic features others have had for years.
