"Format Column" to show "Name From Data Source" as Captiol Letters
Situation:
Currently, if you try to make a family table using properties from the part... it'll import those properties for the table just fine. But the column name will be set to "Name From Data Source" (this is good). But the problem is that the data source is lower case, while everything else in our drawings are upper case (Capitol letters.).
Workaround:
  • Manually format the columns when they come in.
    OR
  • Maybe a custom back door reprogram solution?
Solution/Idea:
Please add a button to automatically change the Data Source info to Uppercase.
