It would be very handy to have a quick select or select similar option in Inventor.
in sketch you can then select all dimensions, constrcution lines, point,....
in part, you can select all the holes, work geometry,...
in assembly, you can select parts, bolted connections, sub assemblys, work geometry
in drawing, you can select views, dimensions, text...
in presentation, you can select all the trails
And could also be beneficial in all the other environment that inventor has.
