I was missing the possibility in the Autodesk Inventor Software to project cutting edges selectively.
The default Autodesk Inventor command: Project Cutting Edges projects all the edges visible within the Inventor View.
This projection contains under most circumstances a bit to many edges, and can be error related.
I created this add-in to project only the cutting edges from the feature selectively chosen.
This means that only relevant edges from relevant features are projected where needed.
All non relevant edges from non relevant features, that can lead into errors are not included.
This means that features that are deleted or changed cannot give an error of missing geometry.
Maybe this is a good idea for future releases of Inventor.
