Prioritize Horizontal/Vertical constraints over perpendicular/parallel constraints!!
I'm sure I'm not the first person that has mention this frustrating part of Fusion. When you currently draw a second horizontal or vertical line in sketch, F360 will automatically assigned perpendicular or parallel constraint to them instead of horizontal or vertical. Is there a way to set priority of which constrain to use over the other.
Horizontal and vertical lines should be able to stand alone as a constraint instead of depending on other lines. and there would be less visual clutter because only 1 constraints icon will be created instead of 2. And personally I'd prefer to use most strict constraint possible
same thing could be applied to collinear> parallel, concentric > coincident, ect
and i know everyone has their preferences, so it should be a setting option for user.
