We frequently use section views in both part and assembly models. They are too necessary commands, and we always cut and uncut models while we are working on them.
For instance, when we are working on a shaft-hub-like assembly, we continuously cut the model by using say, XY-Plane for a half section view. In brief, the commands and operations we use are: Half Section View - Browsing for the section plane - Plane selection - Modelling - End Section View - Looking over the result - Half Section View - Browsing for the section plane - Plane selection - Modelling - End Section View - Looking over the result - etc... If you are using Quarter Section View at that moment, you have to browse for two section planes for plane selections for each and every use of the command... There is no need to explain how hard to browse and select the desired section planes in a crowded featue or component tree.
Therefore, I propose a new command, Previous Section View which remembers our previously used section command option (half, quarter, three quarter) and section-plane selection(s). By using this command, we can reach our last section view by not selecting the same section plane(s) again.
