Press brake option for Contour Flange
We quite often have circular sheet metal profiles that can only be bent using a press brake. In order to draw these profiles you either have to create two separate sketches then use a lofted flange between the two to get the press brake option for these circular features. The other process is to create using a contour flange then rip the face where you want the press brake option and then replace with a lofted flange. Would be awesome to integrate this option directly into the contour flange feature where you can select a specific bend in the part and change it from a smooth profile to a press brake profile. This would be similar to the corner options when creating a flange on multiple edges.
1 Comment
gmwi
Add the "step brake" option to fold also. Behrn57 is correct about only the loft feature having the step brake option. 95% of all bends with large radius's are produced on press brakes. Please expand the option.
