Preset customized property formats in parameters
Parameter: Add the possibility to preset customized property formats in parameters (like export parameter, value exactness,….)!
Parameter: Ich hätte gerne die Möglichkeit, benutzerdefinierte Eigenschaftsformate (wie Exportparameter oder die Genauigkeit) bei Parametern schon als Voreinstellungen festzulegen!
3 Comments
b_ruijter
You could do that in a custom template.
74321Admin
Yes, but most colleagues don´t work with parameters. I do.
But I've given up trying to get our key user to set things like this in the template. So it would be helpful if I could do those settings just for me.
b_ruijter
You could also write an ilogic rule that wil create these parameters. If you set your event trigger for this rule on "on creation" that would work fine.
It would be the same as if it was in the template itself.
