Hi all,
I would suggest a pre-defined setting which defines the options of the feature.
I would like the following:
Right now the options above are hard coded. I would like to edit those standard values with the register or a XML-file.
This gives us a faster work-flow since you don't have to select every single option.
Thanks in advance,
