剖面线的建议
剖面线的建议
样式编辑器中已经设定好—剖面线的的角度为45°。
但是在对部件做剖视图的时候,零件与零件之间是已剖面线的角度区分,有时为30°,有时候为120度,建议根据设置,剖面线始终为45度,零件之间用比例来区分。
5 Comments
EvanGu
Translation:
The angle of the hatch is set to 45° in the Style Manager.
When creating a section view of an assembly, parts are differentiated by the angle of the hatches that sometimes are 30° and sometimes are 120°. It is recommended that the angle is always 45° that is defined in style setting, but differentiate the parts by scale.
r_lehmann79
Hello
this option can be set in the Style and Standard Editor
See Online Help here: http://help.autodesk.com/view/INVNTOR/2016/ENU/?guid=GUID-B37BB51A-FC14-4D78-BDE0-D3DC8FA9C9DF
Best regards
R.Lehmann
EvanGu
Thank you, R.Lehmann.
EvanGu
Hi Symayl,
在样式编辑中,如果把Preset Value里Section Hatch Angle的值删除就可以保持所有剖面线为默认样式的角度值,对于ANSI 31,那就全部是45°了。
要自动对相邻零件打不同比例的剖面线,如果零件材质不同的话,可以在Material Hatch Pattern Defaults里根据材质,设置不同样式的剖面线。
inv.ideareview
Status changed to: Archived
