When creating a pattern of an assembly that is on a custom view rep the pattern follows the first assembly with custom view rep as it should but if you then change the pattern number the additional elements are all on master why? its a pattern it should follow the original. If you want individual view reps that's fine but there should be an option on right click on the pattern in the browser for that. Plus if you change the view rep on the original they should all change its a pattern. This is currently no good for configurators as things are showing up that should not be there. This works for LOD so why not view reps?
![76.JPG 76.JPG](https://forums.autodesk.com/t5/image/serverpage/image-id/124865iF1761190DDE837E1/image-size/large?v=v2&px=999)
