Is it possible to add a CheckBox to Pattern Component (circular!), where this would enable to number of instances to be used to divide 360 degrees / number of instances automatically, without having to type the formula and the variable in the Editbox below.
Example (as per view below): suppose we want 8 instances divided over 360 degrees. You would give the number 8, and check the box, where the division of 360 degrees will be done automatically. Just like the normal circular pattern in parts.
