Pattern flexible components
The component pattern tool currently will not accept a sub assembly which is set to flexible. Why not?
14 Comments
mikeh4
I'd like to see a pattern be flexible next level up.  We model hardware bags as flexible then the next level up we constrain parts.  We can't use a pattern in that hardware back because you can't make a pattern flexible.  The reason we'd use pattern in the hardware bag is to get multiples given pieces of hardware in a quick organized manor.  Now we have to put each instance in manually and either organize them so it looks decent for the IDW by moving them or actually constraining them.
Thanks !
Looks like AutoDesk still did not solve this issue.
I have an idea maybe work:
You could make an iAssembly which includes all of our constraints and other configurations what you want. Everytime, you bring out the one what you need, then you shoudl be able to pattern them.
jeffsteiger6735
Bump for a MUST HAVE in the next release......
scottmoyse
I assume driving the pattern with a flexible parameter doesn't work for you?
dusan.naus.trz
I want to make it work. Why does it not work? Using, for example hydraulic cylinders.
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
pasi.annila
Yes - why?
dusan.naus.trz
Why? When using a hydraulic cylinder. So you want to use the position. How to use a position if you do not have a cylinder as flexible and you can not move it in the field so it's not good.
pasi.annila
Sorry Dušan,
what I ment was that why can't I pattern flexible parts.
You got my vote!
There is similar wish:
https://forums.autodesk.com/t5/inventor-ideas/pattern-flexible-components/idi-p/4382380
Pasi
dusan.naus.trz
@pasi.annila
Thank you for the link. I voted. The theme is 6 years old. Now Inventor 2019. It's not yet. That's not so good. Maybe in Autodesk asleep?-)))
DRoam
I don't understand why this is blocked. Why can't the patterned instances just use the same resolved position as the master instance?
Hunteil
This question comes up a lot here too. I often forget that this isn't possible and I'm left scrambling every time. It's so simple. Yet creates so much work for everyone else b/c it's not a feature.
Here's a great simple example. (PS: These are kit assemblies.)
g_colombi2KRBH
Any update on this topic? we are using Inventor 2024 and still is not possible to pattern flexible components..
We use them a lot for machines support feet that can be rotated to be horizontal also if the machine will be placed sloped.
So, flexible components, but still we have to place them and give constraits manually..
