Show only
Search instead for
From the drawings I've seen in Inventor they didn't have those little surface line details I've seen in patent drawings I've checked out on Google patent search.
It's been a long time since I did a patent drawing, but I don't remember putting any of those shading lines in like you show. I just made a standard engineering type drawing and it was fine. I think those are likely either very old drawings, or the drafter chose to add them to help illustrate the contours of an organic surface(like in your example).
If you're filing for a patent then your patent lawyer should be able to answer your questions about what's required on the drawing better than I can.
Try creating a new file using one of the available drawing templates and see what you can come up with.
Run through some of the drawing tutorials in the help section if you're having trouble.
I am also looking for a way to add the linear shading lines to my drawings for a patent. I believe that a utility patent doesn't require linear shading lines but a design patent does.
In the past I've had to export the inventor drawing file to a .dwg and manually add the linear shading lines. This sucks and takes for ever. Now I have to do it again but was hoping to find an easier way.
Thanks for sharing your Idea. The product team continually reviews this forum aiming to deliver in the most impactful way we can based on voting. We also regularly examine the list to make sure it reflects the most current Ideas. As part of this process we archive old Ideas that haven’t received broad support. This ensures there is room for new Ideas to be reviewed by the community and for the most relevant and meaningful ones to gain votes.
This Idea is archived because it's been on the board for over a year and hasn't received many votes. If you want to raise it again and try to gain more support across the community, you're welcome to do so. Leveraging images, animated gifs or sample mock-ups can help convey concepts and generate more votes from other users. If you have questions or see a connection between this Idea and others that should be accounted for, please let us know.
I was a long time Autodesk user but I converted over to Blender and do all my patent drawings by first creating 3D objects in Blender. Then there are ways to get the render to look like line art using the grease pencil option. Once rendered I convert to vector and use Illustrator to polish it up. It works great. Check out https://americanpatentdrawings.com to see some samples of our work.
