Parameterise loads in Stress analysis
Give us the possibility to parameterise the loads in FEM.
I want to be able to set a range of loadcases or load dependent on other variables.
4 Comments
el_jefe_de_steak
@Thetigerpirro You could implement this with some simple iLogic.
Thetigerpirro
@el_jefe_de_steak
The suggestion is here because is shouldn't have to. Since I can already pick other variables to change I don't really see why load isn't one of them.
But I am curious, how do you suggest I fix this with iLogic?
el_jefe_de_steak
@Thetigerpirro All FEA loads are stored as parameters. After looking at it, you can add expressions in the Stress Analysis parameters to make the forces parametric. The trick is that you have to multiply/modify the forces by a "unitless" value.
If you needed something a little more complicated, you can use iLogic similar to this.
paramA = Parameter.Param("LoadA")
paramB = Parameter.Param("LoadB")
forceUnitString = " lbforce" 'this intentionally includes a space
'The "if...else if" statements are iLogic's version of case statements
If Multiplier = 3
	paramA.Expression = 4 & forceUnitString & " * Multiplier" 'this is how you would set the expression to show the equation
	paramB.Expression = 9  & forceString 'you must include the force string in the ilogic when setting FEA parameters
ElseIf Multiplier = 2
	paramB.Expression = 6  & forceString
Else If Multiplier = 1
	paramB.Expression = 3  & forceString
End If
el_jefe_de_steak
@Thetigerpirro
Actually, you can simplify the iLogic even more by using
Parameter.Param("LoadA").Expression = "3 lbforce"
 If you do this, you don't have to declare your variables in iLogic.
