Overridden Displayed Value dimensions
In the drawing environment , is there a way to check or isolate the dimensions with overridden values?
I copied a design with some overridden dimensions and its difficult for me to determine which values are true and which values are overridden.
It will be a good idea to make the overridden dimensions different from the true dimensions. It could be in different color or line weights or some other markings.
Thanks!
Christian
3 Comments
dusan.naus.trz
This topic already exists. I have a link to iLoigc in the comment.
https://forums.autodesk.com/t5/inventor-ideas/color-dimension-difference-in-idw/idc-p/9083096#M36654
Hi, Thank you for your reply. Just found out that holding shift key + right click on the mouse will prompt you to select all overridden dimensions. I guess this was already added in Inventor 2019 without using iLogic feature.
dusan.naus.trz
I think it's better if the dimension has a color resolution. Sometimes dimensions must be overwritten.
