Origin Indicator
Origin Indicator
Please add the ability to delete (not just hide) the Origin Indicator!!!
18 Comments
Bill_Bogan1
Adding onto this request because I think there is opportunity here to make the origin indicator a derivative of the Centermark object.
ToddPig
The sooner the better!!!!
RDG3PO
This is super frustrating. The origin detached, and reattached to a non entity somehow. Cannot delete, cannot re-position, cannot recover.
suomenvaimennin
Why are we voting to fix an obvious flaw. Just fix it.
r.vanderend
Still not fixed in 2019..
ToddPig
Adding ideas to the Idea Station is useless.  There are hundreds of good ideas that never get implemented, and many more that never get submitted because of the same fact.
It would be great if Inventor just went away.
nico
Ellowah
Being able to delete this (with or without dimensions attacked to the point) is indeed a long term short comming which should be easily fixable?
But I would also prefer to either assign a different symbol to it instead of the default circle aka create our own custom one trough the symbol creator and use a different naming scheme for each since different country's have different names for heightlines especially in water constructions.
Atm I'm adding a "height reference pole with markings" as a part in each assembly (large scale) to allign several bigger assembly's together, since the assembly's and other parts can change so not always optimal to use those as reference
It would also be prefferable that you can assign it once in an assembly and then reuse it in all related drawing views together with using several reference points with their own mark to which one the dimension is refering to
Some1 also mentioned on this topic (but archived) to allow the markers to be (auto)moved to the border of the drawing which is also not a bad idea bad to find them
So it's easier to align, verify and/or draw reference lines from them just because this system is wel: Bad
Being able to project planes from the assembly's/parts into drawings as lines might also ease this.
sschulteH6WZ3
Please add delete origin indicator instead of something useless like a new skin.
@sschulteH6WZ3 careful.. they may add more skins and make them available via microtransactions just to spite us 😄
TheBeardedEngineer
2021... aint this just amazing...
North American mechanical design jobs are fading. It simply costs too much to design with extra time and hassle that projects can never account for.
Inventor may be left to growing countries with cheaper labor cost, unless issues like this are promptly resolved.
whamlin
...bump for 2022.
Shawn1000
It's truly outrageous that this has not been fixed after so, many, years!
Yijiang.Cai
Many thanks for posting the idea to us, and tracked as [INVGEN-64842] for investigation.
prasidh_k
2023 and there still isn't a delete option! Wow...I thought moving across from Solidworks to Inventor was a good thing. Looks like I may have to convince my new employer to get SW instead. So many minor issues like this have carried on for many versions of the software in my last two months of research.
ChrisMitchell01
Status changed to: Accepted
A solution for this Idea is now available for test in the Inventor Feedback/Beta Community. If you would like to try it then you can apply for access using http://Autode.sk/InventorBeta.
whamlin
Make a no-plot layer and place the origin indicator on it.
Yijiang.Cai
This idea has been implemented within Autodesk Inventor 2024.1. Please review the Inventor 2024.1 What's New article here. For more information regarding how you may leverage the feature, and please review this page. Special thanks to everyone who cast a vote for it.
