multiple selection custom iproperties
Is it possible to make a multiple selection of iProperties. Like when I want to delete some custom IProperties (not all like here https://forums.autodesk.com/t5/inventor-ideas/delete-all-in-custom-tab-properties/idi-p/8100462).
In my oppinion the "Modify" button and the "Name" and "Value" field can stay gray. Only the delete button should be highlighted. Like this:
Best regards
Torben Westhöfer
5 Comments
PaulMunford
Hi @torben.westhoefer
You might find it easier to do this via the BOM editor.
You'll need to add your custom iProperties as columns in the BOM editor first.
torben.westhoefer
Hi @PaulMunford
but then I can only delete the value and not the entry in the IProps?
I had some STEP Models to Import and I have many custom IProps. From the Step file there are many custom IProps that I don't want to see in the list. That's also why i won't delete all the custom IProps.
PaulMunford
I think that you are correct. iLogic seems to be the only way currently.
dan_szymanski
Idea added to backlog for future consideration [25615]. Thanks!
dan_szymanski
This idea has been implemented within Autodesk Inventor 2020.1. Special thanks to everyone who cast a vote for it.
