Multiple Punches in One Punch Command.
We deal with a lot of sheet metal and have a lot of punches that we use. Some times we will have a set of punches at an angle and the same set at a different angle on the same face.
  1. It would be a massive time saver if you could do more than one punch in one command instead of having to go through the process of selecting the punch command then finding the punch then applying it.
  2. Also the ability to apply different types of punches on the same face in the same command.
  3. The punch tool could work like the radius tool in that you can select different corners and apply different radii to each one.
Thanks Drew
