Multibody Desigg, "Set Sheet metal rules" with thickness that do not follow rule
Hi
I have a need for a feature, that we are missing more or less every day.
We are constructing HVAC units, and we have lot of different "SheetMetal" parts that are Isolation as the suppliers needs DXF cutting files. The problem is that the different isolations can go in steps of mm from like 5mm to 250mm,and there is like 40 different materials. and maintaining 10.000 different Sheet material rules, will be very time comsuming.
Now the improvement!
When you right click on a solid, and pressing "Set Sheet Metal Rule" for the individual solids, it will be very helpful, if this would have the same functionality as as pressing the "Sheet Metal Default" where, you can remove the mark, of "Use Thickness from Rule" and the same, as using a different material pr Solid instances.
