Multi-Select for Task Scheduler
Not sure how many use TS, but I swear by it for numerous things, but the one thing that still bugs me about it is that when I need to select a bunch of files, I can't multi-select.
No way to use Ctrl-select or Shift-select. This has been the case for years.
It also fails to remember the folder I'm working in, so after each file I select, I also have to re-navigate to the folder.
This is crazy and beyond stupid when one has 10 or more files to select.
Tell me there's some trick I just never found (I've searched here and nothing).
So, I beg of you, add this simple functionality to TS ASAP Puhleeeez!!!
3 Comments
Oh and let me also add to fix the timed schedule option.
I mean this app is called a "scheduler", it would be really nice if the ability to set a task to start at a specific time would actually work in this app.
dan_szymanski
Hello @Anonymous ,
The functionality seems to be functioning as expected within Autodesk Inventor 2021 Task Scheduler. I am able to select multiple files with a Shift-select, or Ctrl-select to add or remove files to my task. I also expect this was the case within earlier releases. I would be curious to learn what specific task or workflow you were attempting that was not working for you?  Please reach out to me direct. Otherwise, I am setting this as "Implemented". Thanks! -Dan
tobias
Apparently somebody removed it again in 2022. Anyone the same issue in TS 2022 ?
