Multi-level instance properties
New Inventor 2022 instance properties are a high potential feature. We are just discussing mechatronic BOMs with device tags (several "equal" sensors with unique IDs) .
Right now, instance properties are restricted only to the direct parent assembly. So if for example a sensor is used on a lower level assembly, there is no way to tag it anymore.
 From a plant/system view, device tags for identification need to be defined on top level assembly for all leaf components.
3 Comments
Please improve the Instance Properties to make them work with sub-parts like the iProperties.
Tags (3)
I completely support this idea.
Currently the only way to use instance properties across multiple levels is by saving and adding the subassemblies under different names so that each sub-assembly can have its own instance properties. It kinda defeats the purpose of instance properties on one hand and working with sub-assemblies on the other hand.
Yijiang.Cai
Many thanks for posting idea to us, and tracked as [INVGEN-96828]
