iFeatures as new Bodies
iFeatures are an old, but powerful Feature of Inventor.
Since the age of this functionality, you can only place iFeatures in already existing bodies, but not start a new body with an iFeature.
Starting a new body with an iFeature like you do e.g. with an extrusion shouldn't be too much of an effort and probably do for a JDI.
This could be very helpful in multi-body-parts.
Also when you want to use iFeatures in Factory Assets.
18 Comments
Create new body to iFeature. Same Extrude and other Features in Part
Tags (1)
bverboort
I'd like to be able to place an iFeature into a part file and have the option to create it as a new solid body on placement...
This would be in addition to the already available option to select which existing body an iFeature is added to.
In addition, please enable the existing (above described option) to select multiple existing bodies so iFeatures can cut or add material to multiple participants (bodies).
Best,
Brian
Tags (3)
PaulMunford
iFeatures in 2017 cut multiple bodies (yay!). The other ideas would be great though!
Option to create an ifeature (such as equal angle) as a new solid body for multi body solids
Frame design in a multibody part would be useful.
pcrawley
Particularly useful when adding iFeatures like steel-sections to a multi-body part prior to generating an assembly from the bodies.
Current workflow involves adding iFeatures and then splitting the body, which is an extra couple of features rather than a simple option when placing the iFeature.
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
Is it possible to create ifeature that brings with it several bodies?
For example we define 3 extrudes as an ifeature, when we place them in the desired part, can be inserted as 3 diferent bodies?
dan_szymanski
Hello @Anonymous
Today, the multi-body support within ifeatures only works on cut operations.  If this request is important to you, I would suggest authoring a new Idea for it, as this one was archived due to limited support (8 votes).  Regards -Dan
Just for my info. What do you consider the minimum votes to start considering some idea?
I can have some ideas for ifeature but I need to develop them.
dan_szymanski
There is no secret antidote for consideration.  We have implemented ideas that possess a wide range of votes (this can be proven by reviewing (filtering on) the implemented ideas to date).
Carson_Gus
In order to properly support multi-body solids, the Insert iFeature function should allow the user to insert as a new solid.
Currently, the command will not compute if an iFeature is inserted into a multi-body part and no input is given for the Solids selection.
This function would be useful in top-down design, especially in frames, where structural extrusions could be inserted as new solids with minimal user input.
Tags (3)
gcoombridge
How has this only got 11 votes?
xenocatalyst
I have just come across this problem myself.
chris
For those of us designing using multiple solid bodies within a single part file, it would be nice to be able to utilize the flexibility and power of iFeatures with the added option of creating a new solid body when placing the iFeature.
Small thing to ask but it would really help that workflow.
Yijiang.Cai
Many thanks for posting the idea, and tracked as [INVGEN-82410]
xenocatalyst
This needs to be a thing, I got to testing ifeatures again today and this lack of functionality renders the useless once more.
