Show only
Search instead for
In Inventor we have only the ability to design only circular gears not bevel gears, worm gears, gear rack, etc. Can you introduce them all in the Gear Component Generator.
@tedod13202 have you ever used Design Accelerator to generate the gear? Is it the right tool for you to design the gear? Please have a try. many thanks!
Hi, in Inventor there are only three types of gears: spur gears, worm gears and bevel gears. But there are mare than this three types: Involute rack, Cycloid rack, Crown gear, Timing gear T-shape, Timing gear, Lantern gear, Hypocycloid, screw gears gear and others. For example rack and pinion gear are widely used but not exist in Inventor.
