modify geometry for flat pattern
when you are working with sheet metal you want the ability to modify the geometry of a flat pattern for an example holes, bevels ect.
now all the geometry changes that you will make on the flat pattern will be removed after going back to folded part.
the need for that came from our need to drill a beam in folded state and make a spiral out of it, the drill are for stairs assembly.
another example, if you want to make a cone with bevels at the sides you cannot do it in the flat pattern.
3 Comments
swalton
avishai_m
Hello Steve,
i tried the unfold/refold features, and it works,
so what is the different between this feature to the flat pattern feature?
what was the flat pattern design to solve that the unfold/refold features does not solve?
M.Hawryluk
Unfold and refold are features you use to modify unfolded shape. You can unfold selected bends or all bends. You can also add other features after unfold/refold.
Flat pattern allows you to see/export the end result.
