Currently the measure tool in 2018 gives the minimum distance as well as the x,y,z distances between finite objects you select.
The above only works on finite objects that you've selected, though. When selecting non parallel lines or splines, for example, you really only get minimum distance and, somewhat meaningless, x,y,z distances.
I propose adding two features:
- Add a maximum distance measurement
- Add a drag-able dimension bar for dynamic measurement
Thanks for your consideration
