Current limitation
In an Inventor drawing with many sheets that each show a different iPart member of the same factory, every sheet has its own independent views, dimensions, and text annotations. When copying views from one sheet to another, you can duplicate the existing annotations and then switch the referenced iPart member, but the copied dimensions and texts are no longer associatively driven by a “master” sheet; later changes must be repeated manually on each sheet.
Proposed solution
Introduce a master sheet concept in drawings that allows other sheets to reference its views and annotations as associative instances. Linked sheets would:
Benefit
Such a master‑sheet mechanism would dramatically reduce repetitive work when documenting many iPart instances of the same part, because common views and annotations would be authored only once and reused associatively. This would lower the risk of inconsistent dimensions or missed updates between sheets, improve drawing quality, and save significant time in projects with large iPart families or similar configuration workflows.
