Make all "Edit Dimension" dialogs have a resizable width
When you edit the value of a sketch dimension, the textbox width is resizable.  When you edit the dimension of an offset workplane, it uses a different dialog with a very narrow, fixed width.  This makes it difficult to edit long expressions.
3 Comments
Gajus61
There are more non sizeable boxes, where the possibility of changing the size would be advantageous  (e.g. for "change model references" or the "add-in-manager")
Genicee
I agree not with just the edit dimension dialog, but there are many dialog boxes etc that need to be re-sizable. Even if it doesn't save the size of the box between sessions. The ability to resize dialog boxes would be well received.
jeffg28CLY
@GeniceeAgreed, I've run into many like this. Anything that pops up like that should be resizable.
I just ran into this one, with text of "<<>> (90.000 NOM. POST LENGTH)"
