Show only
Search instead for
Not quite what is being sought, but maybe it helps.
Sub LockRotation()
Dim oDoc As Document Set oDoc = ThisApplication.ActiveDocument
Dim oInsert As InsertConstraint
For Each oInsert In oDoc.SelectSet
Call oInsert.ConvertToInsertConstraint2( _ oInsert.EntityOne, _ oInsert.EntityTwo, _ oInsert.AxesOpposed, _ oInsert.distance.Value, _ True) Next End Sub
I have recently been through numerous older assemblies, created prior to the "lock rotation" being added to the Insert constraint. Having an option to select either a single or multiple Insert constraints and right click "lock rotation" would be a massive time saver. Rather than having to edit each Insert constraint and ticking the box. Especially where assemblies are using a lot of fasteners, where "lock rotation" is really helpful to quickly lock a component in one constraint.
I'm with @Mtimmis-Personal all the way. This feature just makes sense to have along with being able to sort multiple constraints at the same time too. For the time being I have been using this Ilogic code to speed up my workflow: oDoc = ThisDoc.Document oNamer = "Lock/Unlock Insert" Dim UNDO As Transaction UNDO = ThisApplication.TransactionManager.StartTransaction(oDoc, oNamer) 'Your iLogic code goes in here: '------------------------------------------------------------------------------------------------------------------------------------- qLock = InputRadioBox("Select one:", "Lock Rotation", "Un-Lock Rotation", True, "ilogic") oLock = ThisApplication.ActiveDocument Dim oInsert As InsertConstraint For Each oInsert In oLock.SelectSet Call oInsert.ConvertToInsertConstraint2( _ oInsert.EntityOne, _ oInsert.EntityTwo, _ oInsert.AxesOpposed, _ oInsert.Distance.Value, _ qLock) Next '------------------------------------------------------------------------------------------------------------------------------------- UNDO.End
