We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
Let us edit Suppressed Constraints
As title says.
19 Comments
DRoam
Great idea. Sometimes I suppress a constraint, change a few other things, and then I know I really need to edit the Suppressed constraint before I turn it back on or it will conflict with my changes. It would be nice to have a clean way to do this without risking undesired changes when I un-suppress a constraint, or having to delete it and create a new one.
Andrew2803
Just an other idea, somewhat related this:
Couldn't we take benefit from a possible option of making any constraints "driven", same as dimensions in sketches?
Just an other versatility, to avoid messing (deleting) existing constraints, what we might need later or so...
@DRoam? Anyone?
DRoam
Lol, take a look at this Idea I created some time ago: Driven "constraints" similar to driven dimensions in sketch. So my answer is definitely yes 😉
However, a very similar idea which currently has more votes is this one: Add Measurement as Paramenter. It wouldn't solve the problem you've brought up because it more implies adding Parameter functionality to the Measure tool (which, from what I've heard, is poised for some very overdue improvements soon). This may be the better solution because the new Measure functionality may be more versatile than what we could achieve with Constraints.
But I think both ideas are good, and I'd be happy if Autodesk implemented either. A vote for either or both would be a good thing in my opinion.
Andrew2803
Thanks @DRoam, both ideas been kudoed!
DRoam
@dan_szymanski, just wanted to see if I could poke some attention at this idea. I'm hoping it might be one of those "too easy/obvious not to" changes. This can be a game changer when making careful changes to delicate "house-of-cards" assemblies.
If it could also be changed so that deleting a constraint while "Defer Updates" is on doesn't update the assembly, that would be great. These two changes being made would make doing those careful changes to delicate assemblies much more feasible and less of a train wreck.
dan_szymanski
Status changed to: Accepted
Accepted idea [714]. Thanks!
@DRoam this one definitely qualifies.  Your second issue (made on 1-6-2017) may be a defect.  I have passed it along internally.  Thanks! -Dan
DRoam
Fantastic. Thank you!
Andrew2803
Hi Guys, @DRoam@dan_szymanski
Thanks for accepting this idea, I'm sure many of us will make benefit after implementing this feature to upcoming versions.
It may worth considering build in this little option also into constrain dialog / optionally ribbon if @DRoam's idea gets accepted:
http://forums.autodesk.com/t5/inventor-ideas/tick-box-for-constrain-dialog-to-remember-which-type-wa...
It is really a pain to pick all the time what constrain we want to use, it is should be an option to pick to remember of last used solution.
Just an idea!
Thank you.
Is there an alert function (Like an auto alert by email when the status of an idea changes)? I would love to be able to stay in touch with the status of this idea and many others
DRoam
Hi @Anonymous. You're automatically "subscribed" to an idea whenever you comment on it. Or, you can manually subscribe without commenting by clicking on "Idea Options" in the upper right hand corner and clicking "Subscribe".
To make sure you receive email updates for your subscriptions, go to Site Preferences (in the upper right), click on "Subscriptions & Notifications", go to "Notification Settings", and enable whichever email notifications you want.
SteveMDennis
@Andrew2803@DRoam@Anonymous
Let me ask you a clarifying question, would you need/expect to be able to edit ALL values of a constraint?
Clearly we would have to turn off preview, and editing the offset is probably trivial but do you need to change:
  • Type
  • Geometry Selections
  • Solution (mate to flush, etc.)
  • Constraint set
  • to/from transitional
  • to/from motion
Obviously the reason I'm asking is some of these are harder to do without doing a solve. How hard will it be to change the geometry selections but see nothing happen because preview is off and it's suppressed? you can't be sure you got it right...
If your 99% workflow is to change the offset what about enabling just the quick edit box for suppressed constraints?
DRoam
I wold expect to be able to fully edit the constraint, just like I can when Defer Updates is turned on. I tend to think I'm pretty clever and can keep track of what I've changed Smiley Wink If I break something, that's my fault, but I want to be able to make all the changes I need to, just like I can with Defer Updates turned on.
One very important thing, though. I would want the following indicators to update even with Suppression turned on:
  1. The constraint name (i.e. Mate:1 changes to Flush:1 if I change from Mate to Flush)
  2. The referenced component names that are shown if the "Display component names after relationship names" App option is turned on.
  3. The selection highlights (blue and green highlights) that show on the model when I hover over the constraint.
  4. The offset value at the end of the constraint description in the Browser
If those other indications didn't update, then yes, it would be VERY difficult to track what changes I've made to suppressed constraints. But with those indicators being updated, it's fairly easy. And fortunately, all of those already DO happen even with Defer Updates turned on... all except one.
That's one odd thing about editing constraints while Defer Updates is on. Numbers 1-3 DO happen, but number 4 doesn't. So with Defer Updates on, I can easily check if I've changed my selections/solution types, but I can't check if I've changed my offsets as desired without actually editing the constraint.
So what I would want all boils down to this:
  • Make it so editing a Suppressed constraint is just like editing a constraint with Defer Updates turned on and I have all the same controls.
  • Make the improvement that editing a constraint with Defer Updates/Suppression turned on makes Number 4 above happen, in addition to Numbers 1-3.
Andrew2803
Hi @SteveMDennis,
Thanks for your question.
Please if possible, make suppressed constraints editable same as their unsuppressed relatives.
Most of us may would like to see the full functionality even in suppressed state.
Thanks for you and your team's efforts towards this!
Yijiang.Cai
We are just talking about constraint here. What about Joint? Is there the similar requirement here?
Andrew2803
@Yijiang.Cai, I must confess, not familiar (yet) with joints as never used them.
Please open a brand new thread to that topic.
DRoam
I personally couldn't care less about joints... Smiley Happy
But in the name of consistency, for the sake of those who do use joints, anything that works for one should work for the other. So yes, there is a similar requirement. But it'll be other people complaining one day if this isn't done for joints, not me Smiley Wink
dan_szymanski
This idea has been implemented within Autodesk Inventor 2018.2. Special thanks to everyone who cast a vote for it.
Andrew2803
Thank you Guys, great job!
jeanie.wayker
See here for more info: What's New 2018.2
