Laser cutting of tubes, bars and profiles.
In my opinion, CAD systems MUST follow new methods of technology production. Nowadays is normal to work by laser cutting of tubes, profiles or bars. Here an example that is a mix of prismatic and sheet metal modeling.
This solve and increase production by use only one part instead 3 and less positioning time, welding time and weight!
8 Comments
I actually see 2 issues with this model.
1) problem with the functioning of the bending tool - it has to be done manually, around and around, to bypass the blockages.
2) tangential surfaces - after bending, adjacent surfaces cannot touch each other (this causes the surfaces to become uniform); distance should be added.
But if Autodesk doesn't add this option soon, I will record a tutorial about it on YT.
gusi_cl
Hi, the image posted is only an example and probably is impossible to produce in reality.
Here a short video where is possible to model in Inventor and after realise the part.
https://youtu.be/SEagx1JVkTk
The profile from the first photo can be created in Inventor in less than 5 minutes (in one part file). It can also be produced.
Hello friend
Look at this:
https://youtu.be/pALRFYrxXjc
miechh
That last post from kacper.suchomski is awesome. Didn't know of that approach; using a sheetmetal part to create a 'flat pattern' of a tube/profile. It seems a workable 'work-around', I think I would use it until Autodesk integrates this functionality in about 15 years.
I'm really glad @miechh
I can only invite you to subscribe to my channel: https://www.youtube.com/@mech-design-ks
Many of my current and future tutorials are about "limits circumventing" in Inventor.
I don't think this functionality is a priority for Autodesk because:
  1. As you can see - it can be done.
  2. The model takes less than 10 minutes; configurator - less than 20 minutes.
    If you create an iLogic/iPart configurator, you have a ready-made, automatic library forever.
  3. Dry geometry modeling takes even less time (note that I spent a lot of time on parameterization)
  4. Even with a configurator/library, it can be done faster.
    This example is a universal combine with many variables - cut pocket, pin, and even the selection of material for production (determines the rounding).
    Removing these functions reduces the number of required logical rules. On the other hand, a complete configurator without compromises is worth several minutes of work.
Here's another example:
https://youtu.be/6Irmh55mg2k
