Keep sketches and views in drawing templates
When setting up templates, often it's handy to draw out standard sketches or place base views of certain parts.
However when saving it as a template and starting a new document all the sketches vanish and Inventor forces you to select a model to replace your baseview.
There is a very cumbersome workaround with autocad blocks, but this doesn't work in IDW's and it's also a shame that you can't just do this from within Inventor.
So, please add the ability to use sketches and "fixed" base views in templates.
With kind regards,
1 Comment
k.hendrickx
edit: to clarify, I know you could add sketches as sketch symbols, but you can't annotate these.
For example I wanted the create a drawing of a profile, which should always have similar tolerances in the cross section, instead of specifying these over and over again, I just wanted to add a baseview of a cross section and annotate this one time for all future files.
