Joint improvements/fixes
Joints are a very useful way of assembling things and could do with a few improvements I believe.
1. I actually consider this an error in the joint process but I guess it's not truly a bug so I'm asking for it here. When using the 'Origin Offset' option in a joint, it is not easily possible to go back and edit the 2nd selection point after creating the initial joint. If you edit the joint and click the 2nd point button you can only select a point from the original part and not from any other part. We should be able to.  There is a work around but it's a bit tedious.
2. It would be much easier to understand and use the 'Offset origin' and 'Between Two Faces' options if they were right on the main dialog box instead of requiring the user to hit the right mouse button between selecting the first and second point selections to find these options. (Took me a while online to even find out that these options existed with joint creation!)
3. Along with this, it would be Very useful to be able to select the center point of a face that is made up of two faces separated by a distance. I realize there is an option "Between two faces" but it doesn't work to give you this center point in this plane.
