ISO GPS: Missing ISO 14405, dimensional tolerances, symbols
Starting position:
  • Inventor allows to define dimensional tolerances on 3D model (i.e., 3D annotation)
  • Tolerances can be retrieved on 2D drawing ensuring drawing and 3D model is synchronized
  • 3D dimensional tolerances can be used for middle tolerance STEP exports and tolerance chain calculation
  • 3D dimensional tolerances should be the master to define tolerances only once
Issue:
  • Not all ISO 14405, dimensional tolerances, are available on the 3D model
  • If a missing modifier is needed, they must be added on the 2D drawing (where it is available) but the link to the 3D annotation is lost
Solution:
  • Minimum: Add the missing ISO 14405 symbols to the 3D annotation list as they are available for 2D drawings
  • Optimal: Allow to select available symbols in the Styles Editor as possible for 2D drawings
    All symbols from ISO 14405 and ISO 1101 are available for 2D and 3D
>>> Please support the initiative to be able to comply with ISO GPS, which is applicable since 2011
Same Request also created on enterprise priority support (Case ID: 18088673)
1 Comment
dan_szymanski
Idea added to backlog for future consideration [55556 & 55599]. Thanks!
