Inventor Vault Prompts Settings & Vault Prompts settings: Via API
Make it possible to edit/change the "Inventor Vault Prompts Settings" in inventor; and the "Vault Prompts settings" in Vault, via API.
This is not implemented yet and is only editable Xml Edit.
4 Comments
It looks like you shared the idea with Autodesk to add the ability to change them and in vault. I appreciate the help. Not aware how to do that. Thanks for the help
Hi @Anonymous,
Don't know what your question in your comment exactly is?
Could you please explain it further?
Regards
pball
I need the ability to disable and re-enable these prompts to make my batch processing scripts work nicely with Vault and not require constant user interaction, which was the point of making a script. It's annoying that ThisApplication.SilentOperation doesn't affect these prompts or that there isn't another option for these prompts.
g.georgiades
