Inside inventor nesting, I have been struggling with the problem of source labels. Source labels are the numbers on your part when you nest. It tells you what number goes with its corresponding part. The problem I am struggling is that the number on the product are not shown all the way. half of the number is on and half is off. This is a struggle when you have hundreds of parts in a nest. I would love to have the options to the middle of the object in the nest, and be able to choose the size of the number in the part so it will work with rather small objects, you will be able to see it more clearly and it will have more use.
The pink number is the problem i'm having.
