Inventor IDW define Layer for IMAGE
In the TitleBlock I have inserted a QR-Code as Image.
Now when I export the drawing to a PDF:
- the TitleBlock is on a specific Layer (blue colour)
- the Border is on a specific Layer (green colour)
- the RevisionTable is on a specific Layer (pink colour)
but the image is on the Layer 0 (red colour).
When I go to edit the TitleBlock and select the image, I want put it on a specific Layer (in this case on the same Layer as the TitleBlock).
I want to do this manually and/or through the API.
At the moment this is not possible.
5 Comments
perX7YAP
I want to push this question. Is there a solution for this?
MairA_DUKA
No, until today I don't have a solution or an answer from Autodesk
perX7YAP
Okay, that was sad to hear.
Because my problem is that I have to be able to put images and Shaded Views on different layers. Now both are on layer "0" which means I can´t hide the image if needed.
jasonhannHXE7B
having this same problem, has there been any updates to fix this?
MairA_DUKA
Until now there is no update to fix it
