Inventor Exports Version
When Inventor Exports to Revit, what is the Revit version?     Using Inventor 2022 right now.
Thanks...Randy.
3 Comments
ChrisMitchell01
Status changed to: Gathering Support
The version of rvt exported is dependent on which version of the Inventor-Revit interoperability module you have installed. Most likely it'll be exporting rvt 2022 unless you've installed a newer version. Currently there aren't any  Inventor export options to control major version.
James_Willo
From Inventor 2026 onwards you can select the version you want, from RVT 2023 upwards.
Yijiang.Cai
Thank you for the idea, and it should be implemented in Inventor 2025. You could get more details here.
