Inventor Drawing Automation
Inventor Drawing automation should use more AI technology. To Produce working drawings on the fly when making new parts and assemblys. Default drawing should show flat pattern in sheet metal and auto dimensions  sheet extents.
When you are finished the part the AI system will have the drawing created which you can edit later if needs be. I think a feature like this would give Autodesk the cutting edge of technology in the market of 3D cad design software.
Look forward to seeing this in future versions of Inventor
Regards
P Neville
21 Comments
admaiora
Hi!
The times are ready. It would be great to obtain automatic (totally) drawings based on drafter verbal input.
The same then could be applied to other Inventor task.
Thanks!
mirko.saiani
Only we look in the future?
mirko.saiani
ok ... but I want to respect of law (UNI, ANSI, ATEX, etc etc) .... i'm a big dreamer
admaiora
Yes!
admaiora
By the end of this year (2023), Fusion will launch a new AI technology to have automatic fully dimensioned views from 3d models, with just one click.
 Can we have in Inventor a AI approch too?
mirko.saiani
Admaiora can I see something online?
admaiora
Hi Mirko,
it was shown at AU 2023.
Not updated now about that.
Cheers
admaiora
karram
Invnetor 2024 for any AI implement by using ilogic or API?
m.buehler1
Autodesk Fusion allows now the automated creation of 2D drawings from a 3D model.
It would be a big time saving if a similar feature would exist inside Inventor.
See Fusion 360 blogs, for example
https://www.autodesk.com/products/fusion-360/blog/ai-drawing-automation-in-autodesk-fusion-revolutio...
Tags (3)
stefano.mazzer
Great idea!
If it's not possible in the short term to do this directly in Inventor (due to AI / Cloud / etc.), it would be useful that an Inventor user can somehow seamlessly use this functionality in Fusion, including the possibility to have it Automated (part of API).
gonzatto4W5JK
Any updates on this?
m.buehler1
Unfortunate yes .. we got from Autodesk support the info that they have right now no plan to integrate this to Inventor (that would be upcoming Inventor 2027). Not an official statement, it may change in future.
There is also no API on Fusion 360 which could be used from an external (desktop) application to automate generating 2D drawings out of 3D uploaded to Fusion 360.
HenkdeB
Maybe take a good look at SolidWorks, They are already doing this.
Autodesk come on. When will this be available?
mirko.saiani
uffff
karram
Can anyone @HenkdeB send the solid works link will look that
mirko.saiani
there's a partial solution ... you can use AI to write a code (visual basic) ad use this code to make your design.
ok it's a first step ... but for simple items it works
karram
@mirko.saiani can you give some sample or overview to start.
mirko.saiani
the prompt I used:
create a visual basic code to use in inventor 2025 where it asks me for the values ​​to create a parallelepiped
