Inventor Drawing automation should use more AI technology. To Produce working drawings on the fly when making new parts and assemblys. Default drawing should show flat pattern in sheet metal and auto dimensions sheet extents.
When you are finished the part the AI system will have the drawing created which you can edit later if needs be. I think a feature like this would give Autodesk the cutting edge of technology in the market of 3D cad design software.
Look forward to seeing this in future versions of Inventor
Regards
P Neville
