Inventor command line
Add an optional command line where you could type the command name (with autocomplete suggestions). It may be faster for rare commands.
1 Comment
MattH_Work
The search box (top right) act like 'quasi' command line
Just type in the command you are searching for. it will give you any matching results (depending on environment), where the command is located (Riboon Tab & Panel) and can also be used as a shortcut by just clicking the result
