Show only
Search instead for
Inventor Action Recorder similar to Autocad Recorder would be a great time saver!!
Action Recorder in Inventor Manage TAB similar to Autocad would be a very valuable time saver for repetitive Inventor command tasks. Long overdue for Inventor and would provide the same value as in Autocad!! Everybody sound off on this one 🙂
I have seen that there are several different ideas that deal with almost the same issue.
For a successful implementation on the part of Autodesk it would probably be good if all efforts were bundled in one post... Maybe you also support this effort, which can be found at the following link:
