Improvements to Automated Centerlines
I would like to see some improvements to the Automated Centerline dialog box and command.
1. I use the same exact options every single time for each view in my drawing.  (Shown below)  This typically gives me most, if not all of what I need. Currently, I need to reselect these options for each new view that I wish to use Automated Centerlines on.  At the very least, I would like to see my selections persist during my session.
2. I would like to see an option to allow you to apply Automated Centerlines to multiple views at one time.  This can be achieved by having an option to Select Views within the dialog box.
5 Comments
PaulMunford
What happens if you select multiple views before running the Automated center line command?
I think Centerline tracing in dendritic structures acquired from confocal images of neurons is an essential tool for the construction of geometrical representations of a neuronal network from its coarse scale up to its fine scale structures.
jaybowser38
Paul, you are absolutely correct and I am kicking myself for not trying that first.  Thank you!
PaulMunford
Well done 🙂
I have voted for this idea, if you are able to edit the idea title, you could change it to something like:
'Persistent settings for Automated Centerline Dialogue'
If you think that is a good idea?
Paul
 The performance of this algorithm, which is validated using datasets from DIADEM is shown to be very competitive against other state-of-the-art algorithms. Improved automatic centerline tracing for... (PDF Download Available). Available from: Tutuapp 9Apps Aptoide
