improvement of 3D-annotations
Since the main work on new designs is done in the 3D model, the idea was to display all important dimensions/notes in the 3D model.
If the annotations can be accessed in the drawing, drawing creation is more effective.
It is also advantageous for our production if all tolerances are visible in the 3D model.
However, there are some things that are not well suited to our use cases.
Examples are given below:
- Dimensions cannot be seen in 3D and 2D sections; dimensions cannot be placed on the section view.
- Guide line texts and dimensions are not available in all views; weld seams are
A part of the solution will be maybe the introduction for Independence of layers for guide line texts and dimensions.
Is there a way of getting better options regarding 3D annotations?
2 Comments
Sergio.Bertino
Autodesk Support
Thank you, @markus_trestl , for this Idea.
I would also add to this Idea, the possibility to change easily and effectively the plane where the 3d Annotations lay on a section view
james.joyce4
I have created a post with other opportunities to improve 3D annotations which ties in quite well with this: 3D Annotation Dimension Snapping and Part Number Balloons
