Show only
Search instead for
There is a crosshair of sorts during line/circle/point,etc... creation in sketch mode of parts,etc...
Personally I see no need to increase the crosshair size as Inventor already projects a dotted line from the crosshair automatically to any end/mid points,etc.. of other sketched geometry..
no vote for me.. Just wanted to provide that information..
Ah, that makes sense, thanks for pointing that out, @mcgyvr. I'd tend to agree that the dotted line is sufficient.
For me personally, the only reason I use a large crosshair size in AutoCAD is for more precise window selection (I can see if I will or won't include something in my selection even if it's on the other side of the screen from where I start my window-selection). I almost never have a need for precise window selection like this in Inventor.
yes in autocad having the larger pointer had some benefits..
I wish the Windows Snipping Tool had the ability to increase the pointer too..
But yes window selection is a perfect example of when a massive crosshair is beneficial.. But in sketch mode (which is the only place it really comes up.. in Inventor there really is no benefit.. other than to make Inventor mode like Autocad.. which is a bad thing)
Helpful tip in regards to the snipping tool, if you're interested: You may or may not like installing third-party software, but I use a little tool called Greenshot which is FANTASTIC for taking screenshots and includes a display-spanning crosshair as well as an XY-coordinate indicator. Also allows you to re-capture the same area, and includes an editor with some handy markup and labeling tools. I've used it for years and it's always worked amazingly well, and never shown any signs of malware or noticeable CPU consumption. If you're interested you can download it here: Greenshot.
Does it matter to YOU...It matters to ME, hence why I am asking it.
I see this in the forums all the time...It doesn't matter why I am asking...there is a reason for my question for MY needs.
I found this page looking for an answer of how to increase the crosshair size in Inventor...because when I am doing complicated 3d sweeps or Tube & pipe items with lots of derived/included geometry, the cursor gets lost in the screen...I want it larger.
I come to this page; and find no answers & similar pages asking "Why would you want to do that?"
I use both Inventor and AutoCAD, often side-by-side in a dual monitor setup, and have done so for the last 7 or so years. I see no particular advantage to the AutoCAD-style crosshairs.
Can you elaborate on how you think this would improve usability? Is this an issue of visually losing track of the mouse cursor? If so, there are probably options in the Windows mouse cursor settings that would do just as good of a job as an AutoCAD-style crosshair would do at resolving it.
Hi @jskim00. This has already been discussed here. Please take a look at this discussion.
As was pointed out there, Inventor rarely (if ever) requires the fine-precision selecting that makes the large crosshairs so useful in AutoCAD. Can you list a few situations where crosshairs would be useful enough to warrant the development resources, display clutter, additional application options, etc.?
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes.
We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that
pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know.
- Inventor product team (Inv.idea review)
I realise this is an old post that received very little attention but...
Crosshairs are useful for a quick, visual check of how items are aligned relative to each other without messing around with starting commands. At the moment, all you can really do is pan the edges of things to the edge of the screen. It also makes it easier to find the centre of the cursor and provides a very easy reference to where x,y and z axes are.
It's quite disappointing - but not surprising - to see someone from Autodesk mocking the suggestion because Autocad is "from the 80's." If Inventor's developers had paid more attention to that program from the 80's when building Inventor, it would have been a lot more user-friendly a lot earlier on. Here we are in 2019 and they have only just added a "properties" window after more than 20 years of development, and that only works inside certain functions so it's not really a properties window anyway!
@brett_holmes Hi Brett. I apologise for my flippant comment, and I'd like to point out that I wasn't an Autodesk employee when I wrote it. Keep up your good work in the community.
@PaulMunford 오랫만에 이 글을 다시 보게 되었고 당신의 댓글을 읽어보니 여전히 당신의 이름 옆에는 Autodesk라고 적혀있고 사과의 대상은 내가 아니라는게 어이가 없군요. It's been a while since I read this article again, and reading your comments, it's ridiculous that Autodesk is still written next to your name.
