Improve Symbol Leader Positioning
Can the leader functionality be improved to allow automatic switching from right to left when the leader angle causes the leader to cross over the symbols contents.
Example a symbol used in place of leader text to store common text information. If you position the leader on the left side you are stuck if you need the leader to be on the right. You need to make a new symbol with a right positioned leader.
This works really well in Autocad leader text where the leader will switch from right to left based on the angle of leader.
