Improve Angle Dimensioning
A sketched horizontal line needs to be drawn to dimension this particular 2 degree dimension. Yes, I could use a 98 degree dimension but want to show the 2 degree draft. Side note: It is department policy not to use model dimensions.
Idea: Programmers create an "Angle Dimension" button under "Annotate".
  1. Select the angled feature line.
  2. Right-click mouse, select "Angle from" (in this case, I would select the intersection/vertex).
  3. Right-click mouse, select "Orientation" (in this case, I would select the axis or any other feature that is parallel). It could also be a scroll out for "Horizontal, Vertical or Aligned"
  4. Place dimension.
This sequence could also be done under the existing "Dimension" button.
Autodesk Inventor Professional 2020 64-Bit Edition
Build: 373, Release 2020.3.4 - Date: Fri 10/30/2020
