It would be great if, within the iLogic Rules Editor, on the Model tab, in the same area as Model Parameters node and the "View: Master" (Design View Representations list) node, there was a node there for Solid Bodies
Perhaps this item would only visible when you have a MultiBody Part open, or perhaps it is always visible, but only populated when you have a MultiBody Part open.
Then by simply double clicking (or right click menu option) on an available Solid Body in the list, it you can:
As it stands right now, I have to take a screen shot of as many of my Solid Body names as I can fit onto the screen at a time, before switching from the Model Tab to the iLogic Tab, then to the External Rules sub-tab, to access & edit my external rule. Then use that screen shot as a guide to manually enter these names into my code where needed.
There's got to be a better way.
Yes I know how to use either iLogic code or VBA code and loop through all solid bodies within a part document by name, but this would just make so many things simpler, easier, & faster.
